Si & EX transmission Question
Old May 30, 2014 | 01:51 PM
TOP91's Avatar
Default Si & EX transmission Question
Will a Automatic transmission from a 2000 Si work with a 96-00 EX?
Old May 30, 2014 | 01:57 PM
Fliptard's Avatar
Default Re: Si & EX transmission Question
are we talking Canadian SI?, I'm pretty sure no USDM 99-00 SI came with an auto.
Old May 30, 2014 | 02:08 PM
TOP91's Avatar
I am not sure. There is a guy in VA that has a pile of civics behind his shop or something he is parting out. I would probably have to go out there and pick and pull. He has a craigslist add for a "2000 Honda Civic SE" automatic. I dont even know what an SE is i just assumed he meant SI.
Old May 30, 2014 | 02:09 PM
TOP91's Avatar
oops yea Si is a stick... this must just be a dx or something...
Old May 30, 2014 | 02:10 PM
NotARaCist's Avatar
I never narc'd on nobody!
I'm guessing you aren't talking USDM, since the USDM SI doesn't have an automatic option.
If you're talking CDM, the answer is still no. The CDM '00 SI has the D16Y8, whereas the CDM 96-00 EX has the D16Y7. The transmissions have different gear ratios, and because they are controlled by the TCU (which is integrated into the ECU), you'll throw a CEL, and the car won't shift correctly.
Old May 30, 2014 | 02:11 PM
NotARaCist's Avatar
Oh, so now we get some clarification, awesome.
The Civic SE (Special Edition) has a D16Y7. Answer is still the same, for the same reasons.
Old May 30, 2014 | 02:12 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ +1 for this guy.
Old May 30, 2014 | 02:30 PM
NotARaCist's Avatar
Since you seem to be having a hard time figuring out what trim they are, look at the VIN. The first three digits should be 1HG. The second three digits should be either EJ6, or EJ8. The second three digits from the donor car need to match the recipient car.
Old May 30, 2014 | 05:04 PM
TOP91's Avatar
ok. thanks
modman
Honda Civic (2006 - 2015)
28
Aug 21, 2006 10:45 PM
Syndacate
30
Apr 19, 2006 10:04 PM
90Accord-R
21
Apr 8, 2004 10:11 AM
Feuerraeder
Mar 14, 2003 01:46 PM
EVIL Hx Coupe
Jan 5, 2002 07:53 PM
