Weird idle issue
Old May 29, 2014 | 01:47 PM
HondaCivicSE's Avatar
Default Weird idle issue
I have a manual 2000 Honda civic d16y7 with 200 000 km on it. I have this weird idle issue that only happens in stop and go traffic, while driving in stop and go traffic for about 15-20 min my car start idling at like 1500 rpm then 3-5 min later at 2000 rpm then 3-5 min later at 2500 and it just keeps getting higher and higher, then after I get out of traffic and drive for about 3-5 min in 4th gear and come to a stop my idle is back to normal.
Old May 29, 2014 | 01:56 PM
ElectronBlue00's Avatar
Default Re: Weird idle issue
Inspect your car for any vacuum leaks... and/or lose or disconnected vacuum lines. If everything checks out, clean your IACV.
Old May 30, 2014 | 08:29 AM
What should I use to clean out my iacv?
Old May 30, 2014 | 10:05 AM
Here's a good run down on what you will need and how to do it.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Old May 30, 2014 | 01:17 PM
Former User's Avatar
Clean the throttle body and adjust the throttle cable to have some slack/free play.
Old May 30, 2014 | 01:29 PM
i already cleaned the throttle body and cleaned the IAT sensor about 2 months about and it didn't help, I also check the slack on the throttle cable and its good.
Old May 30, 2014 | 01:30 PM
https://honda-tech.com/forums/showthread.php?t=1575913
thank you
Old May 30, 2014 | 01:31 PM
Sure sounds like the throttle plate is sticking open. You might want to try cleaning it again.
What CEL codes?
Old May 30, 2014 | 01:53 PM
What CEL codes?
No codes but it only happens while im in stop and go traffic for like 20 min
Neomaczen
Honda Civic (2001 - 2005)
Jul 2, 2013 03:04 AM
cstone
Jan 17, 2011 07:42 PM
itzyaboyzeem03
Sep 30, 2009 04:11 PM
ludedude808
Oct 18, 2006 04:52 PM
