Gsr Head/valvetrain noise
Hello everyone, I have ran into a problem. I just had a complete motor rebuild from the machine shop probably has under 6000 miles total since rebuild. I have done the valve lash adjustment 2 times one before first start up and one after this noise has started to develop. It has a quite loud tick knocking if you will coming from the head. I Have a video i took that you can better see what is going on its intermittent some times its quite louder than other times. I have stock valve springs and gsr cams. Any input would be great , thank you.
video here
video here
Intake valve lash .006 .007 exhaust .007 to .008 the noise is sometimes quiet other times a bit louder....could my rockers be out of spec? Im looking into all possible solutions. The video wouldnt load off my i phone but i will get it on here somehow. Someone said lma's but its a p72 gsr head couldnt be that.
if you figure it out I have the exact same thing going on, p72 head on ls block figured before I rip it all down and freshen it up I should ask
filipedua
16
Sep 21, 2006 01:23 AM
