Crazy Temp Gauge
Every time I turn on my brights the temp gauge goes all the way to the highest (hottest).
This also affects the fuel gauge.
When I turn on the headlights to normal and turn on the blinkers the temp gauge goes up and down with the blinker coming on.
Just plain weird.
Just plain weird.
It could be a few other things, but it definately sounds like you forgot to ground to your chassis. Check your grounds. Should be a ground from battery to chassis, and battery to tranny for starters
Check the wiring at connector C405, there may be a short in the wires. A short is an accident touching of an exposed wire to ground or another wire.
92integraVTECgsr
Feb 22, 2018 08:33 AM
