a/c install a bit confusing
Old May 27, 2014 | 05:32 PM
Rmartinez875's Avatar
Default a/c install a bit confusing
Ok so i am installing a/c in my 96 del sol a little confused about the box that goes under the glove box... looks like the previous owner had a ghetto rig because the compressor isnt the right one and it was mounted on what looked like a home made bracket. The lines that plug into the back of the battery are not located behind the battery. .. there next to the battery... is this possible or part of the ghetto rig.... i can go pick up an new box that will lead to behind the battery.. just want to make sure before i go spend the money... I'm trying to post a pic. I taped off the inlets with green duck tape for visual cant figure out how to post pic... new to forums...
Last edited by Rmartinez875; May 27, 2014 at 05:47 PM. Reason: trying to post pic..
Old May 27, 2014 | 05:46 PM
Default Re: a/c install a bit confusing
Old Jun 2, 2014 | 11:48 PM
slowcivic2k's Avatar
LOL, looks like someone added parts from a totally different car. As far as I can remember, all Civic's use a TXV located within the EVAP housing. That is an H-Block assembly, off of god knows what.
Old Jun 3, 2014 | 06:53 AM
fcm's Avatar
fcm
Old Fart
You need the evaporator and evap. housing for a 96 DelSol. 94
4drEF
61
Oct 27, 2015 01:27 PM
GrayT
Nov 14, 2005 04:11 PM
eda6
18
Sep 16, 2004 04:12 PM
B18C_eg
Aug 24, 2004 07:25 AM
sol2nr
May 11, 2004 06:47 AM
