Vehicle making whining noise
Old May 26, 2014 | 06:33 PM
Hatesmakingaccs's Avatar
Default Vehicle making whining noise
Hello recently I started hearing a slight rattle in my car only today it got worse I popped my hood and found out it was a device that my sparkplugs plug into its right on top of the engine and sounds like a bad berring I'm not sure tho any help is appreciated
Old May 26, 2014 | 07:45 PM
RanCRX's Avatar
Default Re: Vehicle making whining noise
If you are refering to the distributor attached to the side of the head of the engine, it has a plastic cover usually black, on a half silver colored casing, then you better take that thing out of your car and replace it. My distributor shaft bearing seized and knocked the timing off. I believe it is what caused one of my exhaust valves to break in half years later. It seizes your camshaft when the distributor bearing seizes because its attached to your camshaft obviously.
Old May 27, 2014 | 10:12 AM
Yes I didn't know it was called a distributer at first it has been sounding progressively louder when idling the last few days is it just the igniter I need? That metal fan thing under the plastic casing
Old May 27, 2014 | 10:25 AM
4drEF's Avatar
Keyboard Humorist
It has nothing to do with the electronics (ignitor).
the problem is the bearing that the shaft rotates on has gone bad. This is not a serviceable part and you need to buy a new distributor.
Old May 27, 2014 | 11:10 AM
http://www.andysautosport.com/honda/1988_1991_crx/performance/ignition/distributors/msd_ignition/ could you see if this is what I need
Old May 27, 2014 | 12:36 PM
4drEF's Avatar
Keyboard Humorist
no. that's the distributor cap.
You need a distributor - the metal part circled in red.
3 bolts hold it on, there are a couple electrical connectors coming out from it, and it requires a tool called a "timing light" to be set into position properly.
Old May 28, 2014 | 12:48 PM
Would anybody know how to tell what coil or whatever it is like TD-01u or TD-02u or what
Old May 28, 2014 | 12:55 PM
4drEF's Avatar
Keyboard Humorist
I assume your car has the stock engine?
If so, then...
What car do you have?
What trim (DX, Si, LX, HF, STD, EX)?
Thriftmaster
Mar 23, 2017 08:28 PM
B88
Apr 27, 2015 05:17 AM
erikiksaz1
Jan 8, 2006 06:23 AM
guttedEF
Mar 28, 2003 11:58 PM
See Are X
Dec 22, 2002 01:16 PM
