MSD digital 6 Plus Question?
Hi guys hope everyone is having a wonderful memorial day weekend. I have have a 97 integra ls with a 01 gsr swap fully built. I have got everything on the msd digital 6 plus hooked up minus the rev limiter. I have the instructions and have looked all over the place for a answer. How would I go about hooking up the rev limiter the dark blue wire. The instructions says it just needs to be hooked up to a 12v source. So do I hook up the blue wire to a 12v source on a toggle switch and the run a ground and everything will work is this correct well I mean the rev 2 step will work. Any advice will be much appreciate
Thanks Guys!!!!
Thanks Guys!!!!
It is 12V+ to activate, run a lead from a switched 12V source, [ign. 2 free pin on under dash fuse box] to an on/off switch and the blue to the other side of switch. 94
Ek00fbp
Jan 31, 2004 09:45 PM
