A/C wiring diagram?
I am trying to turn my A/C switch into a kill switch for my '91 Civic htbk. Does anyone know which wire is for the button toggle?
hello RonJ what year model does that a/c circuit diagram apply to, I don't see anywhere on the image, what this schematic applies to.
Thank You, Alfredo
Thank You, Alfredo
You can get away with using just the blue/red from the A/C switch, it is a ground when any blower motor speed is on, it can be used to trigger a "starter cut relay", [turn a relay on], lust using it allows the A/C light to also work as an "on" indicator.
The switch will not "carry" enough current to use it by itself as the starter cut, unless your car is a 5 speed, [standard] then you can run the CIS, [clutch interlock switch] output or ground input through the switch, use the green lead into the switch for the input and the blue/red for the output, the A/C indicator light will still work. 94
