Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 mdx
Old May 24, 2014 | 01:35 PM
rob2007mdx's Avatar
Default 2007 mdx
Can anyone help, my car has 96k and my ac blows cold most of the time and randomly not cool at all, I replaced the relay and no change any help would be appreciated.
Old May 24, 2014 | 03:45 PM
SpokaneSpeed's Avatar
Default Re: 2007 mdx
When its not blowing cold - is the compressor engaged and spinning?
Old May 26, 2014 | 04:20 AM
rob2007mdx's Avatar
No, it don't engage at all, Looks like the electro magnet is bad, there is 12 + volts at the compressor terminal, thought at first maybe a thermal switch but there forewent appear to be on this compressor, looks like I'll replace the compressor because a new click is 165 through 210 + shipping and I found a compressor kit for 255 with free shipping. If you have any more ides please let me know. Thank you for responding.
Old May 26, 2014 | 01:48 PM
If you've verified you're getting 12v signal to engage, at the compressor connector, then your issue is with the compressor or compressor clutch.
Old May 27, 2014 | 10:20 AM
rob2007mdx's Avatar
I replaced the electro mag coil and it worked for about 5 minutes and it appears that the new coil has burned up, any ideas, the old one ohmed open.
Old May 29, 2014 | 03:56 PM
WanaBeFaster's Avatar
Normally replace clutch/coil, stator, and relay together. did the old relay happen to rattle internally?
Old May 30, 2014 | 03:01 AM
speedlever's Avatar
Out of curiosity, what is the status of the cabin air filter?
GSR936
May 5, 2009 05:25 PM
M15
48
Jul 22, 2006 10:11 PM
97civic123
May 27, 2006 05:50 PM
