Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Misfire with codes
Old May 22, 2014 | 02:18 PM
Rmiller50's Avatar
Default Misfire with codes
2005 honda civic ex 1.7l I have a hard misfire I've been trying to trace down codes are p0300- p0303x2 an p0301 p0304 p0302 valves adjusted to .007 intake .008 exhaust new Ngk lazer itridums new coils seafoamed it twice cleaned egr new intake gasket set and still the car has not changed any ideas
Old May 30, 2014 | 05:32 AM
BigHec's Avatar
Default Re: Help please!!!
How long has this been going on? Maybe bad gas?
Old May 30, 2014 | 11:07 PM
Rmiller50's Avatar
Default Re: Misfire with codes
It been going on for a few weeks now several tanks have gone threw since it started I just did a compression test #1 was at 190psi #2 is 178psi #3 is 85psi an #4 is 180psi ... I checked # 3 a second time this time I added a little oil an it went up to 100psi I'm thinking head gasket or bad rings a mechanic friend said possibly valve seats??? What do you think
Old May 31, 2014 | 02:38 PM
lazlong's Avatar
Do a leakdown test to determine where the compression loss is.
Old Jun 12, 2014 | 11:23 PM
Rmiller50's Avatar
I did a compression test and found that I was 190+/- like 15psi in all but one my number 3 cylinder was 80 psi I thought rings decided to pull the head off an seen that the valves were loose called a few machine shops and I found that it's their #1 and happens with the d17a2 every 100k or less ... so I got an 2005 honda civic ex for sale Lmfao
djsimm89
Jun 7, 2013 12:14 PM
turbo_ef4
Feb 17, 2006 11:55 AM
thehondaguru
Jun 24, 2003 07:41 AM
mick
Jun 7, 2002 07:43 AM
lsvtec42
Dec 6, 2001 12:39 PM
