b series vtec swap tech
Old Oct 30, 2002 | 01:12 PM
JCushing's Avatar
Default b series vtec swap tech
ok i have a b18b in my 98 teg.. now i have a b20 and am going b20/vtec
can i use my fuel rail/injectors from my old b18b? (i know the injectors are the same and am pretty sure on the fuel rail)
can my TB from my b18b fit onto a type-r or b16a intake mani?
i have a skunk2 mani on my b20 now that i also had on my obd 2 b18b... will a type r be the same as the skunk2 as far as sensors go so that i can just swap an r intake mani onto a b16 head?
whats the best way to wire in vtec? can i just plug in a b16a obd2 ecu and wire in a vtec solenoid into the harness? im assuming it would run a b20/vtec fine with increased fuel pressure to compensate for the displacement increase.... or can i use my stock b18b ecu with a vafc... (yes i know about the redline and hondata is better)
Old Oct 30, 2002 | 04:17 PM
tinkerbell's Avatar
Default Re: b series vtec swap tech (JCushing)
this has been extensivly covered before!!!
https://honda-tech.com/zerothread?id=267004
use the search in archives...
t..
use b16a ecu
Old Oct 30, 2002 | 04:24 PM
JCushing's Avatar
Default Re: b series vtec swap tech (tinkerbell)
i dont see anything pertaining to what i asked in there....
im already running a b20 with all my old b18b stuff.. i want to know if the fuel rail/injectors and sensors i have will fit onto an r mani and if the TB will too
i sit at work all day and read hundreds of posts.... its not like i dont try to find the answers...
[Modified by JCushing, 8:27 PM 10/30/2002]
Old Oct 30, 2002 | 04:32 PM
tinkerbell's Avatar
yeah sorry, i thought you were using a B18B manifold
so what you are REALLY asking is:
is the Type R IM same as Skunk 2?
actually, no - that isnt what you are asking -= damnit what ARE you asking????
t..
Old Oct 30, 2002 | 04:35 PM
tinkerbell's Avatar
i dont know, sorry.
t..
Old Oct 30, 2002 | 04:39 PM
JCushing's Avatar
i know that the type R mani is the same in every aspect to the skunk2 ive seen them both.. just the bolt patterns are different.. i just want to kno wif te fuel rail will swap over and the TB will swap over
also what ecu to use for vtec
Old Oct 31, 2002 | 03:17 PM
JCushing's Avatar
anyone else?
Old Nov 2, 2002 | 01:19 PM
JCushing's Avatar
no one?
Old Nov 3, 2002 | 01:48 AM
polymath's Avatar
Yes. The fuel rail will probably fit better without the spacers, however. That was the case with mine.
Old Nov 4, 2002 | 07:17 AM
JCushing's Avatar
anyone else?
Old Nov 4, 2002 | 10:12 AM
Katman's Avatar
Yes, you can use the B18B fuel rail, its exactly the same as an ITR fuel rail. And yes, you can use the B18B TB on the sk2 manifold. You'll also have to swap over the mounting posts for the TB + fuel rail when you get the Skunk2 manifold.
As for the ecu, since you're OBD2 I suggest and ITR/P73 ecu; or if you decide to go OBD1, get an ecu jumper and a reprogrammed OBD1 ecu, usually reprogrammed P28 ecu's are the more affordable way to go.
For wiring, you can stick with your OBD2/LS engine harness & just add the wires for vtec + knock sensor. But lets say you happen to get a 98 type-R or GSR engine harness which already has th vtec wires embedded into it, you'll still have to wire up VTEC components from the ecu to the main harnes shock tower plugs, so you're best of sticking with your orginal harness.
[Modified by Katman, 11:16 AM 11/4/2002]
Old Nov 5, 2002 | 04:03 AM
JCushing's Avatar
Default Re: b series vtec swap tech (Katman)
well i meant that i have a skunk2 intake mani now for a b18b and i was gonna get a type r intake mani since its cheaper than another skunk2.... thanks for all the info though!
4thgenx42
Sep 25, 2006 04:15 AM
EX-T
10
Mar 6, 2004 09:15 PM
cliff666
Jan 1, 2004 07:04 PM
sugarloafpkwy
Sep 20, 2003 07:57 AM
CivicHB_92
Oct 8, 2002 08:56 PM
