Weird main bearing scribe
Hey guys,
I went to. Start the rebuild on my d16y8 today and noticed the code for the main bearing are "messed" up. Like someone took a metal scribe and made different letters with them. I was trying to figure out if they were C's or D's but they don't even come close to matching the old block lettering or even where the location of the letters usually are. So I thought maybe it's just a "different" coding iv never seen before.
My question is, what do you guys think?
This is the messed up one
This is the correct one
Thanks
Thanks
Last edited by Former User; May 21, 2014 at 06:57 PM. Reason: Attempt to fix pictures
See, photobucket requires an account, and is blocked at a number of work places. Imgur doesn't, and isn't.
Hopefully someone else can take a look at that for you.
That first one just looks like gibberish. The second one looks like DCCCC.
Given the possibility that someone else fucked with that block at some point, I would definitely strip it down, take it to a machine shop for cleaning and honing, and bring them the crank as well so they can mic for bearing clearances.
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
ericlee303
Nov 17, 2003 08:54 AM
