Wiring in ftp sensor on 96 dx swap
Old May 21, 2014 | 02:57 PM
hatch_swap's Avatar
Default Wiring in ftp sensor on 96 dx swap
Ok i'm running a 96 dx hatch with 99 b16a2 with 99 ecu with ry wire obd2b to obd2a jumper harness.
So im getting code 91 for fuel tank pressure sensor.
So today I got a ftp sensor from a 98 lx automatic... are the auto/5 speed the same?
and evap canister with solenoid valve on it.
wires I need to wire into the ecu?
and this is a extra plug I have hanging loose that fits on the canister i'm not sure why it's there though on a dx harness?
and here's the pin out
If anybody could help with the ftp sensor part with the 5 wires that's what i'm trying to figure out thanks.
Old May 22, 2014 | 08:10 AM
hatch_swap's Avatar
Default Re: Wiring in ftp sensor on 96 dx swap
ttt
Old May 22, 2014 | 08:21 AM
grumblemarc's Avatar
The Grumpiest
http://www.carolinahondas.com/tech-t...questions.html
Old May 22, 2014 | 09:33 AM
hatch_swap's Avatar
yeah I was on that thread yesterday, I know I could change ecu but i'm trying to bar the car soon..
Old May 22, 2014 | 11:01 AM
420eg95's Avatar
This may or may not help since I know from state to state policies/laws will change.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
if you have a 96 civic won't the use of jumper harness automatically fail you? ... if they see it? (most are marked "for off road use only" at least mine is)
I have b18c1/b16 in a 99 civic ex and I have to run 99-00 ex PTP OBD2b ECU to pass inspection (bar, as you call it) here in NC, I don't know what state you are in but shouldn't you run a OBD2a PTE ECU without a jumper harness?
The way you are doing it in my state it would still fail and its alot of work for what you are doing, if I am wrong please explain as your explanation could help someone else answer your question.
Last edited by 420eg95; May 22, 2014 at 11:12 AM. Reason: corrected obd2 PTE ecu code
B16_ek
19
Apr 21, 2009 04:18 PM
ekhatchturbo
Aug 30, 2007 11:32 AM
VTC_CiViC
May 17, 2004 08:45 AM
