Odd noise when i turn steering wheel
Old Oct 30, 2002 | 12:11 PM
JoshRambo's Avatar
Default Odd noise when i turn steering wheel
yesterday i noticed that when i turn my steering wheel i get a rubbing kind of sound and a little vibration. it sort of sounds like rubbing your funger overa peice of glass. not sure if it is just because of the cold weather and that my car sat for a week while i was on vacation.
what could it be? something with the steering assembly? it does it all the time even after i drive for a while. you can only hear it a littel ousside of the car.
Old Oct 30, 2002 | 12:12 PM
Flux's Avatar
Default Re: Odd noise when i turn steering wheel (Gravity)
That is common in our cars - it is a bearing in the steering rack that has gone dry and needs to be lubed. Take it to the dealer and have them take a look (if under warranty).
Being cold doesn't help it....
[Modified by Flux, 3:13 PM 10/30/2002]
Old Oct 30, 2002 | 12:14 PM
mstewar's Avatar
when you turn the wheel any amount, or only when all the way turned?
Old Oct 30, 2002 | 12:35 PM
buzzman's Avatar
I've owned my R for a lil over a year and it just started doing this about a month ago. Seems to be makin that "dry" sound when the steering wheel is about 1/2 turn in either direction. I had the same thing happen with my '95 GS-R.
It's so annoying!!!
-Buzz
Old Oct 30, 2002 | 12:51 PM
Champ R's Avatar
I get the same thing... when im backing out or turning the wheel at very low speeds its a rubbing screech type noise. Only seems when im going very slow or making tight manuvers. So its a streering bearing that needs to be lubed?
Old Oct 30, 2002 | 01:05 PM
RockstarJR's Avatar
Lube her up.... Nothing major.
Old Oct 30, 2002 | 03:28 PM
JoshRambo's Avatar
Default Re: Odd noise when i turn steering wheel (ITRChris)
it happens whenever i turn the wheel. i will get a hold of my dealer. it better damn well be under warrenty or some heads are gonna roll.
Old Oct 30, 2002 | 03:31 PM
schumiR's Avatar
Same exact thing happened to me and the dealer took care of it under warranty and I've not had a problem since.
Old Oct 30, 2002 | 08:12 PM
slackeR1366's Avatar
same problem here...but for me it's only when making right turns...
need to lube her up
Old Oct 30, 2002 | 08:17 PM
vtec.dc2's Avatar
Default Re: Odd noise when i turn steering wheel (R1366)
anyone knows how to do that? and is it hard to do yourself?
m car makes that noise when i start the car and make the first turn or 2... damn it
Old Nov 1, 2002 | 09:07 AM
vtec.dc2's Avatar
Default Re: Odd noise when i turn steering wheel (vtec.dc2)
ttt... anyone knows how to do that / had similar problem fixed?
Old Nov 1, 2002 | 09:20 AM
Mullet_SyTy's Avatar
mine does this as well, but only in the cold. Just lube the bearing, its easy if you have a Helms to guide you along the way. I had to do mine again this year.
Old Nov 1, 2002 | 09:22 AM
Chris's Avatar
Default Re: Odd noise when i turn steering wheel (98_ITR#396)
Its a rubber bushing for the steering rack. Its common.
Lube it, or take it to the dealer.
onyx00's Avatar
Same exact problem here; was supposed to get it fixed this morning but was too drunk to take it in. Gonna do it next Friday.
Old Nov 1, 2002 | 09:38 AM
ITR764's Avatar
same here, only does it in tha cold. i live in tha south so i don't have that much cold weather so i said fuq it.
Old Nov 1, 2002 | 12:48 PM
SoCal ITR's Avatar
Default Re: Odd noise when i turn steering wheel (ITR764)
Mine is doing it too...
Chris, who's car has been making a lot of noises lately.
Old Nov 1, 2002 | 12:59 PM
rurkster's Avatar
same thing happened to me.. power steering fluid... just dont overfill it
Old Nov 1, 2002 | 01:05 PM
Larkin W.'s Avatar
Default Re: Odd noise when i turn steering wheel (rurkster)
Same thing for me since I purchased my 97' w/ 36,000 miles. I figured it was no biggie. Only happens on my ITR (that I can hear) when im slowly backing up or pulling out of the driveway(Low speed turning)
My 97' needs lots of lube My seat belt joints are squeeky too. I cant wait to lube her
[Modified by EbboyPSi, 4:07 PM 11/1/2002]
Old Nov 1, 2002 | 01:30 PM
JoshRambo's Avatar
Default Re: Odd noise when i turn steering wheel (EbboyPSi)
i am taking it to the dealer in a couple days.
stevescivic
Feb 17, 2008 06:31 AM
aberle99
13
Jan 30, 2008 12:37 PM
VSM EXtasy
Jun 9, 2006 06:07 AM
authentic plusONErandy
Apr 11, 2006 08:47 PM
pr0phet
Oct 21, 2005 11:54 AM
