severe bucking surging and white smoke from dipstick tube
Old May 17, 2014 | 05:54 PM
badcarma's Avatar
Default severe bucking surging and white smoke from dipstick tube
greets guys... to the point. 94 stock cx eg 5 speed... only mod a cold air intake. has a bad isb and and needs cv replaced both sides (bought like this) ive experienced minor bucking surging in first gear very minimal in past but tonight it started bucking hard if I fluttered gas at all in first gear acted like it wanted to grab and go..let off gas apply very little gas and wants to buck hard... popped hood... dipstick vey hot ...removed it to take a look as I had oil changed today (looks good) but white smoke coming from dip stick hole... thoughts fixes ideas...I already did a search and couldn't find anything related ... ive been working at finding an si ex tranny for awhile...this have anything to do with the isb bearing - bad cv joints..pcv? btw vacuum lines look routed correctly I did a lot of searching to no avail.. my temp gauge is fine..no check light or codes... I check my oil often and feel my dipstick is very very hot for several weeks now any help appreciated in advance..
best regards dave
Old May 17, 2014 | 06:05 PM
grumblemarc's Avatar
The Grumpiest
Default Re: severe bucking surging and white smoke from dipstick tube
I don't know where to start with these anymore. Does the CEL actually work? Last tune up? Check mechanical/ignition timing? And yes, the dipstick is going to be hot sitting next to a broiling engine.
Old May 17, 2014 | 06:11 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Old May 17, 2014 | 06:13 PM
The Grumpiest
^^^If that's for me, I'm leaving H-T for good.
badcarma's Avatar
I did a tune up on it 2 weeks ago.... changed plugs, wires, cap, rotor, valve cover gasket, fuel filter.. been running great... thought my only thing left to deal with was fixing the bad bearing ISB in the tranny and do the axles..they have not been cloicking to badly and ive been driving it like a grandma..btw yeah timing is good... but this bucking in first was severe tonight... never experienced anything like it..its a 70 hp cx grabbing like a motor with a lot more hp and lsd... flutter the gas and it bucks like hell...and the white smoke from dipstick tube wtf...pcv only thing I didn't replace when I tuned..gonna do in am again any help advice welcome in advance..what the hell is this
Old May 17, 2014 | 06:16 PM
badcarma's Avatar
yeah and yes cel works..sorry I missed your query
thanks marc
Old May 17, 2014 | 06:19 PM
not for you, actually posted it in the wrong thread, was intended for Cannons, "um my car died on the highway, whats wrong with it? "
Old May 18, 2014 | 05:13 AM
Former User's Avatar
Are you saying that your engine is overheating?
Have you checked the mechanical timing and compression tested the cylinders?
Also, disconnect the fuel injectors and check for bright white spark at all 4 spark plugs.
xaznstyleracerx
Aug 21, 2010 08:43 AM
dano88
Sep 30, 2009 09:12 AM
clazo
Apr 18, 2008 10:49 PM
Skinflute22
10
Aug 2, 2005 07:49 PM
beaterman
Oct 12, 2003 07:48 PM
