auto to manual swap, vacuum assisted mount
Firstly this is for a 96 accord f22b2.
So I'm changing my car from automatic to manual, The automatic has a vacuum assisted rear mount. The 5spd has a regular rear mount, both mount in the same manner with no modification needed While im doing the swap, I'll be changing the ecu to a 5spd ecu as well.
It is a little unclear to me, but will I need to change the rear mount to a solid one? Or can I keep the vacuum assisted with the 5spd ecu?
If i do keep the auto mount, with the 5 spd ecu, i was assuming the solenoid will not open or close, because the 5 speed had a regular mount and the ecu will not detect idle rpm and will not control the valve, I was thinking this would leave a squishy mount?
If i switch to a 5 speed mount, how can i prevent having a vacuum leak? (where and what line do I need to plug)
Sorry seems like a noob question to me, I just think I am overthinking it
Thanks for the help in advance!
Use a manual mount for a manual transmission. Many manufacturers use mounts like this to control engine flex in the mounts. If you cannot control the mount correctly, substitute it for one that is traditional.
Follow fcm's advice, simply cap the line at it's source.
Thanks guys
Cap at the manifold, and plug any vacuum connectors that you are no longer using to prevent debris from entering.
cloud4571
Sep 29, 2012 03:25 PM
turboblack2door
Jun 8, 2011 02:50 PM
civicseth
Apr 9, 2007 11:55 AM
