AC Compressor noise
Old May 15, 2014 | 09:25 AM
delsolo95's Avatar
Icon2 AC Compressor noise
okay 95 del sol with gsr swap using del sol sohc ac compressor and P7J crv bracket. cant really describe the sound it makes, like a clothes drier i guess i dunno
I have this noise coming from the ac compressor with the engine on and ac off.
when the engine is on and i turn on ac (clutch engaged) the noise go away when the ac compressor clutch is disengaged the noise/sound return. If that makes sense.
is the clutch on the compressor bad? from the videos and threads im reading when you turn on ac the clutch will make a sound, but mines is the other way around.
Old May 15, 2014 | 10:25 AM
kyden's Avatar
Default Re: AC Compressor noise
is your idler pulley ok?
Old May 15, 2014 | 01:35 PM
delsolo95's Avatar
yes. i took out the belt and spun the idler pulley by hand and it didnt make any grinding noise or whatever sound they usually make. it spins freely
I did check operation of the compressor clutch cover or whatever it is and it look like it was wobbling when engaging. should i just change it? Autozone sells em for 106.99 plus tax
Old May 15, 2014 | 01:37 PM
Former User's Avatar
Originally Posted by delsolo95
I did check operation of the compressor clutch and it look like it was wobbling upon engagement.
You likely need to replace the compressor pulley.
Old May 15, 2014 | 01:40 PM
delsolo95's Avatar
they only sell the pulley as a complete
Old May 15, 2014 | 01:42 PM
Left to right: Armature Plate, Pulley, Coil
Old May 15, 2014 | 01:44 PM
delsolo95's Avatar
ok thanks for your help! i should be replacing saturday.
Old May 15, 2014 | 01:49 PM
It's a tight space, but it's possible to replace the pulley and clutch without removing the compressor from the car and disconnecting the refrigerant lines, if you're patient and have the right tools.
Old May 30, 2014 | 10:46 AM
delsolo95's Avatar
thanks it was the pulley. i ended up replacing the armature plate, pulley, and coil
Old May 30, 2014 | 11:24 AM
Great!
Just curious - Did you do the job by removing the compressor or leaving it attached to the refrigerant lines?
Crobran
Feb 9, 2017 12:37 PM
DelSol06
15
Nov 21, 2012 02:08 PM
092eg6
Aug 23, 2010 08:30 AM
Azn Kenny
Oct 8, 2007 01:55 PM
PnX-R
Jun 8, 2002 06:36 PM
