Putting a GSR motor into an LS teg
Old Oct 30, 2002 | 11:39 AM
integranator's Avatar
Default Putting a GSR motor into an LS teg
I know this is a n00b topic, but are all the mounts still the same? I ask this because i have an amazing deal on a GSR motor-- and i'm kinda sick of my ls motor-- so what else will need to adapt to fit the GSR motor?
Old Oct 30, 2002 | 12:11 PM
Malice's Avatar
New User
Default Re: Putting a GSR motor into an LS teg (integranator)
it'll bolt right in. u just need to run the vtec lines to the ecu.
Old Oct 30, 2002 | 01:11 PM
Cramerox's Avatar
Default Re: Putting a GSR motor into an LS teg (MaliceGSR)
and a p72 ecu?
Old Oct 30, 2002 | 01:13 PM
Malice's Avatar
New User
Default Re: Putting a GSR motor into an LS teg (Cramerox)
that too.
u can use an LS ecu, and use a vafc to control the vtec, but its a bad idea since the fuel maps are different between the 2 motors
Old Oct 30, 2002 | 02:57 PM
allmotorls95's Avatar
as long as it is a b series motor it will fit directly in
Old Oct 30, 2002 | 04:09 PM
mr_mbuna's Avatar
Default Re: Putting a GSR motor into an LS teg (allmotorls95)
Are the headers the same? Because when I went to buy my Comptech headers, you could get one for the LS/RS/GS/ITR or one for the GS-R.
Ben
Old Oct 30, 2002 | 04:32 PM
Malice's Avatar
New User
Default Re: Putting a GSR motor into an LS teg (mr_mbuna)
I did this swap over a year ago. When I first did it, I used my old dc header I had on my ls motor and put it on my gsr. If you do that you don’t have to modify the b pipe. Right now I have a 5zigen header for a Type R(see avatar) and put on a resonated test pipe. again, I didn’t have to modify anything.
O wait, u have to cut off the one piece off the header that bolts up by the oil pan. No biggie.
[Modified by MaliceGSR, 5:34 PM 10/30/2002]
Old Oct 30, 2002 | 04:36 PM
Tomakit's Avatar
You have to wire
-vtec
-secondaries
-knock sensor
Mounts are the same.
Need a p72 ecu.
Things get a little more tricky if you are putting an obd2 motor into a obd1 ls.
Good luck.
Tom
Old Oct 31, 2002 | 07:10 AM
MugenGTR's Avatar
Default Re: Putting a GSR motor into an LS teg (Tomakit)
hmmmmmmmm......... thas weird, no one else is saying it, DO A SEARCH, hahahha, i'm jus in that meam mood 2day...
jikespingleton
Dec 2, 2006 04:18 PM
CompanyFlow
Dec 5, 2004 06:37 PM
jfoster
Sep 10, 2004 10:04 PM
ITR1071
Jan 3, 2003 02:20 AM
deceit
May 12, 2002 09:25 AM
