why no fire?
Old May 14, 2014 | 02:47 PM
brad813's Avatar
Default why no fire?
I have a 94 civic with a 1.6 97 engine in it has been running good but now it just wont start. I have checked all fuses and ground wires, has new dizzy, and 12 volts going to the coil. ran fine till i got home sat for 30 mins then wont start. Any suggestions?
Old May 15, 2014 | 07:19 PM
reg_lus's Avatar
Default Re: why no fire?
blown ecu fuse 15amp?
Old May 16, 2014 | 04:17 AM
StealthIsKing's Avatar
Assuming engine is cranking over but wont start.
- Check spark.
- Check that fuel is getting to the fuel rail (Remove bolt at fuel rail! CAUTION look away as you might get sprayed with a bit of fuel)
If you have spark and your getting fuel to fuel rail check your injectors or timing.
Old May 17, 2014 | 10:10 PM
fcm's Avatar
fcm
Old Fart
Again a question without near enough information to make anything but guesses. 94
wardawg1991
Oct 9, 2017 08:54 PM
91da_teg
Jan 21, 2009 11:16 PM
ghostcivic
Jan 16, 2007 02:46 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
tnord
22
Sep 26, 2003 08:45 PM
