1991 honda accord lx starts but dies after a min or two
Old May 11, 2014 | 04:46 PM
kcbelak's Avatar
Post 1991 honda accord lx starts but dies after a min or two
i have a 1991 Honda accord lx that i swaped in an f22a6
the main relay is good
fuses are good
ecu is good
gets spark
fuel pressure regulator is good
no disconnected grounds
it will start sometimes
when it does it runs for a minute
fuel pressure is 0 psi
when key is on when you crank it it stays at 45 psi
till i stop cranking and slowly goes down to 25 psi
cant figure out what is wrong please help
Old May 11, 2014 | 08:57 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1991 honda accord lx starts but dies after a min or two
What do you mean by Fuel pressure is 0psi?
Old May 13, 2014 | 10:30 AM
kcbelak's Avatar
when i just turn the key to the on position it doesn't read any thing until i try to start it
Old May 13, 2014 | 01:12 PM
holmesnmanny's Avatar
could be a bad ignition control module
Old May 13, 2014 | 05:47 PM
kcbelak's Avatar
would that cause it to start for a minute then die?
could it also be the injector resister
Old May 13, 2014 | 08:34 PM
never in my life ever heard of a resistor box going bad
a bad ignitor heats up and overheats which causes it to cut off
you can use this site as a guide to test your ignition system
techauto.awardspace.com
Old May 14, 2014 | 09:03 AM
kcbelak's Avatar
thank you
Old May 14, 2014 | 09:21 AM
NerfGunner420's Avatar
why isn't anyone else concerned about the fact that there is 0psi fuel pressure on the ON position everyone else is talking about the igniter hahaha
Old May 14, 2014 | 01:53 PM
because he said when key is on it goes to 45 psi .. but it is a bit ambiguous indeed
keep in mind the fuel pump only primes for a few seconds when you turn to the on position then it shuts off if not started will slowly bleed down to 0
Old May 14, 2014 | 02:30 PM
well he didn't quite say what priming fuel pressure is or was, and i don't know who would post that they have 0psi after prime which is obvious right but either way there should be resting pressure
Old May 19, 2014 | 09:03 AM
kcbelak's Avatar
i got the car to run the idle was at 2000 rpm when i disconnect the iac it goes down to 1200 rpm
i adjusted the idle screw all the way in and then out a little and put an anothe iac now car will sty to run if i pump the cas till it dies and then restart it it runs with a high rpm and slowly drops down till it dies
bonehead48
Aug 11, 2017 08:22 AM
jvcabinetry
May 8, 2017 10:00 PM
Nick Effler
May 19, 2015 10:06 AM
jdmcertified909
May 27, 2012 07:05 PM
subman1
Nov 26, 2007 06:00 PM
