Brake warning light wires
Old May 10, 2014 | 04:42 PM
~sp33~'s Avatar
EFB055
Default Brake warning light wires
Morning H-T.
I'm looking to find where the wires for the brake master cylinder 'low fluid warning' switch originate from. There's two wires, one is a ground the other i can't find on my harness anywhere.
I've looked at the wiring diagrams and it's mentioned in a few places but i can't seem to find it.
Any help would be appreciated.
Old May 10, 2014 | 08:23 PM
Tyson's Avatar
Default Re: Brake warning light wires
you mean the reservoir cap itself?? and/or under the e brake??
or where does it go after that? which harness, etc...
Old May 10, 2014 | 08:29 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Originally Posted by ~sp33~
Morning H-T.
if it's missing, it's most likely cut off at the nearest loom to the cap, should be a ground wire and the wire going to the warning light together
Old May 10, 2014 | 10:25 PM
~sp33~'s Avatar
EFB055
Appreciate the input, but it isn't. I tucked the harness myself a while ago, and for the life of me i'm not sure where this wire went. My guess is that i've routed it with another section of the loom, however the only way to tell is to find where the wire comes from and trace it.
The green/red wire that connects to the cap, where does that go to in the harness?
Thanks guys.
Old May 11, 2014 | 12:50 PM
Tyson's Avatar
its part of the driver side headlight loom with only a 1" lead.
so yes, if you tucked the whole harness, you need to extend it. should be easy enough.
or... dont bother. do you really need that dummy light?
Old May 11, 2014 | 07:00 PM
~sp33~'s Avatar
EFB055
Yeah it should be easy enough. But I can't find it, do you know where the wire originates from?
The problem is that the light remains on, and it's annoying. I could remove the bulb... Or I could just fix the problem.
Old May 11, 2014 | 09:44 PM
Tyson's Avatar
dont you have headlights???
follow those wires...
or just remove the bulb.
Old May 12, 2014 | 12:17 AM
~sp33~'s Avatar
EFB055
The ground wire follows the headlight harness up to the headlight, however the OTHER wire follows X harness under the dash, therefore i'm looking to find where that OTHER wire ORIGINATES from (and it does not originate from the headlight).
Appreciate the quip, would appreciate help more so.
Nisif
Apr 24, 2016 10:59 AM
H23_del_soul
Apr 9, 2010 07:21 AM
numero sete
Jul 12, 2008 07:25 PM
ef9gsx
17
Dec 15, 2007 01:49 PM
Jeremy D. Swain
Jul 14, 2005 05:05 PM
