Question on injector size.
Old May 6, 2014 | 02:45 PM
si90rex's Avatar
Default Question on injector size.
I have a lsvtec and im curious to know what injectors would be enough to support e85 and around 500hp.
B16 head:
P&p
skunk 2 pro 1 cams
flat top valves
skunk2 springs and retainers
Block
eagle rods
je 10:1 pistons
81.5mm bore
Turbo
Sc61 with upgrade compressor
I had a stock b20 with a tiny .48ar turbo with dsm injectors and it worked for pumped gas.
But i have never done and turbo build to this size before.
Thanks
Old May 6, 2014 | 02:53 PM
h22apwrd95's Avatar
Default Re: Question on injector size.
1000's will basically be the bare minimum, and limit you to right around the low 500's. Jumping up to an ID 1300 and a larger fuel pump would be the way I would go. Either a DW301, somebody's 340, or the Big Walbro, any of those pumps will get you to 500. Need to upgrade your pump wiring in the process.
Old May 6, 2014 | 07:41 PM
wantboost's Avatar
Who is Mr Robot?
And it's always better to have more injector than you need. rather have too much and not need it than to have not enough and need more.
1000s would be the lowest I'd go, 1300 or larger would give you a bit of wiggle room on the power levels
Old May 7, 2014 | 11:55 AM
Fuel Injector Clinic's Avatar
Depending on your fuel pump setup, Fuel Injector Clinic 1100cc injectors for the B-Series could be a nice solution.
When these are run around 50-55 psi of base fuel pressure they will support around 500 whp.
If you run a Walbro 450 in-tank pump it should be a good match for this setup as long as you're not running super high boost (up over 35 psi or thereabouts).
Old May 7, 2014 | 12:16 PM
si90rex's Avatar
i have 250 walbro but its a few years old and idk if the e85 will damage it. i know some are e85 safe. ill probably go aeromotive.
Thanks for the input!
lsd96teg
Dec 18, 2010 11:46 AM
axelintegra
Apr 26, 2010 05:17 PM
Mostecstreethb
Oct 4, 2008 04:49 PM
KRWTEK1
Oct 11, 2006 05:59 AM
ebbshatch
Feb 22, 2006 03:36 PM
