SOHC FI set up help!!!
Old Oct 30, 2002 | 09:20 AM
ZEXCRX's Avatar
Default SOHC FI set up help!!!
Hey guys, first off, if i mess this up(which is why i am asking) i know nothing about SOHC motors. Which Honda Hatch has the best SOHC and what is the engine code. I am curious as to what motor is good, cause i hear it is an awesome set up for dirt cheap($250 bucks on hi mileage) what parts should be replaced, the whole bottomend? I am guessing replace all the bearings, Rods, pistons but with stock cams? This motor could be built for less than $800 bucks and it would be able to boost pretty high w/ aftermarket rods and pistons right? What would be a good turbo for the dollar for this motor? T28? spins up quick? help me out guys thanks, btw, you cant run a turbo on this motor bone stock right? at 7psi daily driver? can you?
Old Oct 30, 2002 | 09:48 AM
yellowsub's Avatar
Default Re: SOHC FI set up help!!! (ZEXCRX)
Well since you have an 87 CRX which is a first gen you're gonna have trouble putting any of the later model SOHC's in. Your best bet would be to find a D16A1(dohc) outta a 1st Gen Integra. Or if you're rich rollin you can get swap a b-series motor in there but that is gonna cost you a shitload.
rocketfuelcerx
28
Feb 6, 2005 02:53 PM
Serdar
Jul 5, 2004 07:27 AM
hair_rice
71
Mar 7, 2004 12:06 PM
x James Bond x
11
Sep 22, 2002 10:00 PM
