valve spring compressor attachment?
I need to get the valves back in my D15b7, and the compressor obviously needs some kind of attachment. I have a blue point compressor, its the big hook w/ the big handle.
1. Should I buy the attachment from Honda? What would they call it?
2. Is this also necessary for B series heads? Would it be the same attachment? Since* I need one I would want one that is good for both D's and B's
So I was reading that blue point has one, and IV read Honda makes one.
originally I was considering the thought of making my own, and that may be the route I go down but I'm looking for suggestions/advice/experience.
Buying the actual attachment is stupidly expensive, if you can even find it any more. A number of companies make valve spring compressors for head-on-block jobs. Pick one.
but I wanna make sure IV got the tool to put it back together to cut down on time that the keepers are laying around waiting to be misplaced
http://s1372.photobucket.com/user/fa...ddf42.jpg.html
I was digging thru a box of old tools I dont use, for a socket to fit up, and I found this one, already broken or cut or whatever, looks perfect to me.
what do you guys think? It fits the spring retainer, but its really close and when I held it against one that I took out it seems like it will slide off easily
95gsr@530
Engine Machining & Assembly
Nov 23, 2015 05:42 AM
GoodSkoolRevltn
Dec 11, 2012 11:45 PM
HumanResource
Jan 8, 2009 07:31 AM
