grounding issue??? need help
Old May 5, 2014 | 03:08 AM
leebarbero's Avatar
Default grounding issue??? need help
I have 1993 del sol with a tucked d16y8 and harness from rywire.com
I think im having an electrical issue. My problems are, 1.when the engine becomes warms up till fan kicks on, the engine revs good till I add a load like driving, acts like the fuel is starving. I turn it off turn it back on with gas it goes up the rpms till the computer senses its hot again and bogs out on a load or with throttle. The warmer the engine the worse it gets. 2. My drivers side low beam doest turn on, high beam works, turn signals are blinking fast. I bought a new drivers side head light harness thinking I fluffed the old one, I didnt extend any wires on the new one. 3. Im getting an extremely loud sucking noise from my intake... like really loud not normal at all. <-gotta check timing for that. And valve lash.
The reason why I think it is an electrical issue is because the low beam worked while I tapped the gas a few times just for a short amount of time till the light never came back on.
I 're checked my grounds 3 times. The rywire harness I did exactly how they said to install (milspec). Im getting no cel. Im gonna ground the cel wire to see if there are any hidden codes I may be missing but if I unplug a sensor ie map or iacv I get a code.
Somewhere I feel im not getting the propped voltage, I test the alternator and it is running strong, im gonna add a fpr gauge.
Im at a loss. Dropped so much $ I probably didnt need to and im ripping my hair out. Next shot is a good mechanic but im from mass and there are many dirty shops out here near the boston area that I dont know where to look.
Old May 5, 2014 | 03:16 AM
leebarbero's Avatar
Default Re: grounding issue??? need help
I've switched computers too, I have a stock p28 and. P28 chipped with hondata s300. My s300 actually makes my car run rougher
Johnathan Nuss
Dec 16, 2018 06:44 AM
allmotorgsr98
Dec 10, 2013 02:19 PM
migs2k3
Honda Civic (2001 - 2005)
Jul 3, 2012 07:46 AM
player01018
Jan 12, 2008 11:31 PM
jdmjunkie86
22
Dec 12, 2007 12:56 PM
