Balancing motor necessary?
Old Oct 30, 2002 | 08:42 AM
1fastEK's Avatar
Default Balancing motor necessary?
When building up a block with new rods and pistons, does the motor need to be balanced by a shop? I've noticed some people who installed the parts themselves, don't mention ever getting it balanced. Anyone know?
Old Oct 30, 2002 | 08:45 AM
MikeSarr_GSR's Avatar
Default Re: Balancing motor necessary? (1fastEK)
balancing becomes more critical with applications that have higher cylinder pressures from what I understand. I am sure the majority of people wouldnt do this due to the time and money it would take to accomplish.
Old Oct 30, 2002 | 09:01 AM
1fastEK's Avatar
Default Re: Balancing motor necessary? (MikeSarr_GSR)
Thanks. The main reason I was asking is because a friend of mine is building his B18B up w/ 12.5:1 pistons and i think crower rods. He just spent a sh!tload of money having a shop build and balance his motor, when I know we could have installed the parts ourselves. I guess the money is well spent if you can afford it, but don't know how much better noticeable performance there would be.
Old Oct 30, 2002 | 11:28 AM
GZERO's Avatar
balancing an engine is worthwhile, mostly if you rev high. I read an article that stated that a balanced engine can last 50% more than a normal engine cuz there is no vibrations that can eat the bearings as well as the seals. I would do it without thinking if i have the money.
you would feel it at high RPMS which i'm quite sure he will see.
re rex
Sep 30, 2013 04:24 PM
blufke
Oct 30, 2002 06:34 AM
accordfreak
Dec 16, 2001 07:24 PM
