Battery light on after alt. change
Old May 3, 2014 | 08:23 PM
toytroy's Avatar
Default Battery light on after alt. change
I have a 91 si hb with an b18a1. It had a bad alternator so I went and picked up a new one. Everything is converted over to obd1. I put the new alternator in and now the battery light in the guage cluster is on. I still have the stock obd0 plug if that makes a difference.
Old May 4, 2014 | 10:41 PM
SpokaneSpeed's Avatar
Default Re: Battery light on after alt. change
Sounds like you didn't get something connected back up. Did you have a battery light on prior to the alternator swap??
Make sure your connections are good, and that the alternator belt is properly tightened.
Old May 5, 2014 | 12:20 AM
holmesnmanny's Avatar
parts store alts are known to be bad out of the box.. return it and get another or go denso to be sure to get a working reman alt
Old May 8, 2014 | 07:07 PM
You Mad Bro?'s Avatar
I had a bad ground once that left my lights and electrical crazy...I replaced my entire starting system, from starter to alternator to battery to distributor...finally I changed all my grounds and solved my electrical issues for the most part...
reg_lus
Sep 25, 2013 12:04 AM
haywyre
Oct 9, 2008 12:27 PM
da9pwnsu
Jan 19, 2007 12:12 PM
fe519
Sep 23, 2003 03:25 AM
Alexnaderkeith
Sep 10, 2003 08:32 AM
