H22 Turbo Vtec boundaries
Old Apr 30, 2014 | 08:56 PM
Tadfoot's Avatar
Default H22 Turbo Vtec boundaries
Hi I have a H22 with a T3 turbo running 6lbs of boost it runs great everything is tuned in but I didn't tune it with vtec yet. The car has full new intake, 3in exhaust, 750cc injectors for my 12lb tune. On the 6lb tune though i was wonder what is the upper and lower rpm boundaries I should use for vtec engagement. Or is it even safe to use vtec with a turbo? I just want a general consensus of what rpm range I should set? The car is also sleeved and has eagle rods.
Old May 10, 2014 | 11:52 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: H22 Turbo Vtec boundaries
the only way to tell what your Vtec engagement point should be is to tune it.
Old May 10, 2014 | 12:37 PM
Tadfoot's Avatar
So like trial and error?!?!?!
Old May 10, 2014 | 12:39 PM
Tadfoot's Avatar
Or should I just wait till i have it sitting on a dyno and try to find the point. Heard similar people starting at 5k and moving it around from there to find where the best engagment point is
Old May 10, 2014 | 06:19 PM
Muckman's Avatar
Moderator in Chief
The best way is on the dyno. Like the man said, get it tuned.
Old May 10, 2014 | 10:46 PM
I'm Huge In Japan
it's pretty easy. do a pull with Vtec disabled, then do a pull with Vtec enabled at a low point. wherever the power curves intersect is where you put your engagement point at.
if you don't have access to a dyno you can get pretty close by comparing the low and high cam fuel values, since fuel largely dictates power. that's in my manual, which is in my signature.
es_squared
Jul 14, 2009 07:35 PM
haloae
Sep 21, 2008 08:22 AM
McLude2nR
Mar 26, 2007 06:17 PM
fastrcars
Jan 14, 2006 07:38 AM
