99 vtech smoke issue
Hello !
Let me start by stating I know close to nothing about my Honda outside if what I've read in the manual, so I apologize for improper use of technical terms;
I've diagnosed fault codes indicating catalyst pressure below threshold (p0420). From the research I've done, I need to clear emission system and EGR valve of carbon build up. I'll admit I've been very busy, and money has been somewhat tight, so I haven't been able to do this. Now, I have a white smoke coming up from underneath the vehicle. I can only assume this is because of the carbon build up? I am also changing my oil every 1500-2000 miles now, as it seems to be burning very quickly.
What I am looking for are cost-effective solutions I can do myself, or the knowledge to have a discussion with a mechanic (without having to break the bank). If you would take a look at the image here: http://estore.honda.com/honda/images...S033B0200A.png The smoke is coming from the pipe above #18 & #17, that 'joint'.
Any advice is greatly appreciated.
Last edited by gumby87; Apr 29, 2014 at 10:33 AM. Reason: Update to be more informative
Thanks!
Mine had the same issue, the VTEC was leaking due to a busted O ring. I replaced both VTEC orings, and it eventually stopped smoking. However, it did take a few weeks, before all teh oil burned off.
