HELP! NO START CEL BUT ECU NOT FLASHING
Old Apr 29, 2014 | 07:42 AM
winquest1000's Avatar
Default HELP! NO START CEL BUT ECU NOT FLASHING
Hi guys,
MY car again is having issue, on my way home close to home cel comes on i decided to pull into variety store to loo at the flashing lights on the ecu for cel code (90 civic dx with d16a6) as i pulled in car oil light came on possibly but the car died as i pulled so it couldve been normal
try to start care turns over no start, all lights come on cel is there and ecu is not flashing, it was night so i had to use a flash light, checked all fuses all looked all right, Ive been having a little bit of oil on 3 out of 4 plugs one closest to dizzy was the worst,
I pulled my plugs and the tube was filled with oil around the plugs a lot more then normal
I quickly looked at grounds they looked fine
what im asking for is some ideas for me to try tmrw morning to get this thing going
Summary
d16a6
oil in plugs
car died
ecu not flashing but cel came on oil light possibly came on but may have been car dieing
don't hear to fuel pump prime
car turns over strong but no start
fuses are good
before cel came on and car died hard to accelerate would back fire
my questions
BAD ECU?----what test can i do to check
Oil in plugs- i know could be valve cover seals ill check
bad grounds? i know most grounds could you help me figure ito out
What would or cause the car to die like that after coming off the highway with no issues
Old Apr 29, 2014 | 11:31 AM
Default Re: HELP! NO START CEL BUT ECU NOT FLASHING
bump, guys please I need some suggestions im at a loss
Old Apr 29, 2014 | 08:39 PM
Laserjock's Avatar
If your ECU is bad the only way I know to test it is to try another
ECU fuse is the same as HZ fuse in the engine compartment fuse box next to the shock tower
Distributor rotor is loose
Ignition switch is bad
bighoss77
Aug 15, 2012 06:54 AM
Civic_07
Jul 8, 2009 03:44 PM
asiansgoweeee
May 25, 2005 10:23 PM
5-SpeedFreak
Sep 22, 2002 10:19 PM
