accord problem
Check and see if the small wire going to the starter is getting battery voltage when you turn the ignition to the start position. If it is getting battery voltage then the problem is likely the starter contacts. You can replace the starter contacts if you have a Denso starter or you can just replace the starter with either a junkyard one or you can get one from a parts store.
