Over revving issue
Old Apr 25, 2014 | 06:48 PM
etorres86's Avatar
Default Over revving issue
So I went to take my civic for some servicing, new spark plugs and what-not, also to see if they could fix an issue I have when shifting. Basically, sometimes when I shift to the next gear and accelerate, or just accelerate even after being in gear, it will continue to rev up, and then a couple seconds later it will rev down to where it should be.
The mechanic thought it may have to do with some clutch timing, but that didn't end up being the issue, and the only thought he had as to what it may be is an aftermarket Injen Tech air intake that was installed in the car before I bought it.
Could this be the issue? If so, would an OEM intake fix it? If not, what are some ideas of what this could be?
Old Apr 25, 2014 | 06:54 PM
95accordCE6's Avatar
Default Re: Over revving issue
Any info? What year, how many miles? And no an aftermarket intake won't cause this. Are there any fluid leaks you're aware of? I don't like jumping to conclusions but it sounds like clutch slippage.
Old Apr 25, 2014 | 07:32 PM
etorres86's Avatar
2007 civic si coupe 2.0, about 84k on the odo. I'm not aware of any leaks, it's just odd that it does this periodically. it's not all the time.
Old Apr 26, 2014 | 03:34 PM
It could be either a slipping clutch or a case of the 8th gen rev hang, if that's the case it's pretty much just something you live with
Old Apr 27, 2014 | 01:21 AM
holmesnmanny's Avatar
Sounds like textbook clutch slipping/starting to go out. The clutch disk is basically brake material. Over time it wears out and you gotta replace the clutch disk just like when the brakes go out.
Old Apr 27, 2014 | 05:41 AM
etorres86's Avatar
The last car I had was a cable clutch in a 91 civic hatchback, so I won't lie by saying I've been kind to this clutch. I do burn it more then I should. How do I know when the clutch really needs to be replaced? Is this pretty much the symptoms of when I should start thinking about it?
Old Apr 29, 2014 | 01:05 AM
I would replace it asap. Last thing you want is that thing slipping when you're trying to go up hill or when you need to accelerate.
Old Apr 29, 2014 | 10:42 AM
etorres86's Avatar
Ok, thank you very much for the help, I appreciate it.
bmfmgntcorp
Transmission & Drivetrain
Sep 1, 2017 04:02 PM
denisq6
Honda Civic (2006 - 2015)
Mar 5, 2012 08:23 AM
warabto
17
May 29, 2008 09:50 PM
hondaracin24
Jan 18, 2005 07:31 AM
Special_Ex
Jan 6, 2002 11:43 AM
