B16a2 fuel pressure rises high
Old Apr 22, 2014 | 08:33 AM
BJM3x96813's Avatar
Default B16a2 fuel pressure rises high
I have on my fuel pressure guage that it's reading way past max. Meter does a full circle and buries the needle past max around till it can't go anymore. Why is it doing this? What do I do?
Old Apr 22, 2014 | 09:33 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: B16a2 fuel pressure rises high
It could just be a bad gauge or something like a clogged fuel pressure regulator or return line. If the car is running fine then I would assume it is the gauge. If it isn't a liquid filled one then they have a much higher failure rate. Swap out the gauge for a known good one or use a fuel pressure tester.
Old Jun 20, 2014 | 07:23 PM
BJM3x96813's Avatar
Thanks. It's a liquid filled one but I will try those first
Old Jun 29, 2014 | 04:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
if your PFR is bad then it'll get stuck closed and cause this problem. this is more common on boosted engines.
Bobby_Budds
Engine Management and Tuning
Aug 17, 2011 04:08 PM
hondapowerb16a2
Mar 20, 2010 01:15 AM
insaneconceptz
Jun 14, 2007 09:06 PM
See Are X
Sep 2, 2002 07:26 AM
