cannot set timing right need help
Old Apr 22, 2014 | 07:24 AM
leebarbero's Avatar
Default cannot set timing right need help
D16y8, stock everything, sent head to get surfaced
Problem im having is setting the distributor adjustment if that's what you call it.
The cam is at 9 and 3oclock (to the surface of the head), the up arrow is pointed up like the manual says.
the crank pulley I removed to line the crank sprocket to the oil pump mark.
So im sure its aligned.
Placed the belt around left to right, when I start the engine it runs well due to the car being cold, but when I put the timing gun to it where the notches are I do not see them, the knotches are actually by the power steering pump.
What could I be doing wrong??
Old Apr 22, 2014 | 08:47 AM
leebarbero's Avatar
Default Re: cannot set timing right need help
Im guessing it could be 774-417-035806 degrees off
Old Apr 22, 2014 | 09:40 AM
HiProfile's Avatar
Sorry but I think that would be a negative value (-35449), or did you accidentally add a phone number in front of the number "06"?
If you milled the head and used the STOCK cam gear, your cam is retarded a few degrees. It depends on how much was milled. The distributor will also have it's range of adjustment reduced by that amount. Say the cam is 6 degrees retarded - if you could target 8 to 16 degrees before, now you can only target 2 to 10 degrees. Retarding the timing would put the mark further toward the front of the car. The only way to get it back if the distributor is maxed out is to grind the distributor's ears out or get an adjustable cam gear.
IIRC that motor's pulley is marked a 0, 10, 12, and 14 degrees. A d16z6 pulley is marked at 0, 14, 16, and 18. Make sure you have the engine warmed up and the service connector jumped. That should lock it at the base timing your ecu & engine are set for.
Old Apr 22, 2014 | 11:43 AM
VegasInvasion's Avatar
I'm Huge In Japan
The y8 with a P2P ecu will lock timing at 12*
I have a shaved y8 head and block, it's retarded 4 degrees on a stock cam. you're retarded like 20 degrees, so you're definitely a tooth off.
with a shaved head your cam shouldn't be straight up.
clock the cam CCW a little, get the belt on, clock the cam CW until the front of the belt is tight, relieve the tensioner bolt, clock forward 3 teeth, and tighten.
If your distributor is pinned all the way to the left or right to hit the timing mark, try shifting one cam tooth in the opposite direction.
Old Apr 28, 2014 | 02:34 AM
leebarbero's Avatar
That makes so much sense! Im gonna try this. Thank you for the help I really appreciate the help
Old Apr 28, 2014 | 03:09 AM
leebarbero's Avatar
yea man Damn autocorrect.. im gonna go back and see what I can get done. Ill pick up a cam gear too while im at it
Old May 4, 2014 | 05:41 AM
leebarbero's Avatar
Question, when you say "forward" do u mean ccw?
Katy Pfeffer
36
Aug 9, 2018 08:18 AM
Freemananana
Sep 17, 2015 03:43 PM
Ef4doorwagon
Apr 27, 2014 01:57 PM
revhardEK
Apr 5, 2012 09:03 AM
stevieturbos
Apr 11, 2011 12:09 PM
