Speedo off
Old Apr 21, 2014 | 10:35 AM
Zaridar's Avatar
Default Speedo off
2001 civic ex 1.7 auto BMXA. My actual speed is approx 1.14 times what the speedo says.. I changed the geared speed sensor as it did not gave the correct one in it... Still the same... Any ideas??
Old Apr 21, 2014 | 10:38 AM
JuggerNaut-CTR's Avatar
Default Re: Speedo off
Is it a km/h cluster or mph?
Drastic tire size change recently?
Old Apr 21, 2014 | 12:24 PM
Zaridar's Avatar
Had 195/65/15. Just put 185/65/15 on. Not much change at all. 1 mph maybe... Mph
Old Apr 21, 2014 | 12:28 PM
Zaridar's Avatar
Oh I checked the ECU reading with an actron and the speed sensor is sending the correct speed. Must be the cluster then?? Would a poor ground cause this. FYI. This May or may not be related but the fuel gauge is reading too high, the temp gauge too low, and tachometer too high, also the lighting for the odometer at night is so dim it's barely visible... This is why I'm thinking something with whole gauge
Old Apr 21, 2014 | 12:47 PM
I would suspect the cluster too if thats the case
Old Apr 21, 2014 | 02:29 PM
Zaridar's Avatar
Anyone know if there is a main ground the grounds the whole gauge cluster?
Old Apr 21, 2014 | 03:43 PM
Zaridar's Avatar
Also found I have left front abs sensor malfunction
topshot-rhit
Honda Civic (2001 - 2005)
Feb 24, 2013 09:48 AM
96honda_EK
11
Oct 20, 2009 03:40 AM
d16vteceg
Aug 3, 2006 03:09 PM
mingbling
Jul 24, 2004 11:18 AM
fozzy1
May 14, 2004 12:38 PM
