shifting into 2nd problem...
Old Apr 20, 2014 | 08:44 AM
hillbillycivic's Avatar
Icon2 shifting into 2nd problem...
got a 98 civic hatch all stock d16y7 and rebuild 5 speed tranny.
my issue is when say going around a 90ish degree turn going about 25ish if i try to just push in the clutch and drop from 3rd to 2nd one of two things happens.
1 either i get totally locked out of 2nd it just wont let me in. it wont grind or anything the sifter just wont go in at all.
2 or if im closer to the 20mph mark ill feel a click and it will go half way in than a 2nd click and its finaly in 2nd and i can go.
but if i coast the corner in neutral and then clutch in and go into 2nd its fine. is this a scynchro problem or some kind of linkage problem or what.
Old Apr 20, 2014 | 03:18 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: shifting into 2nd problem...
Have you tried bleeding and adjusting the clutch?
Old Apr 20, 2014 | 05:54 PM
Emeraldbomber's Avatar
Try and see if you linkage isnt hitting off something. If not honda and their infinite wisdom didnt stake the countershaft bearing and that likes to walk out and lock you out of second. How many miles on the trans?
Old Apr 21, 2014 | 02:32 PM
154k total but was rebuilt at a local shop about 4k miles ago with a full bearing/seal/synchro kit from synchrotech. but latly 2nd has been stiffer than the other gears witch are all fine.
no i guess it wouldn't hurt to try.
Old Apr 21, 2014 | 04:41 PM
crazyhouse2011's Avatar
I would explain to the shop your issues and see what they say. If it's a small shop, like a mom and pop shop, see if you can get them to diagnose the issue and fix it since they already got a ton of your money rebuilding it. A lot of rebuilt trannies come with a 1 year warranty.
Or slip them a 50 and see if they will fix the issue.
Old Apr 21, 2014 | 04:47 PM
B serious's Avatar
Does your clutch pedal have a lot of freeplay at the top of its travel?
KPGzDA
Mar 25, 2007 10:55 AM
HOOKSH
Dec 20, 2004 01:54 PM
Outkasted24
Sep 22, 2004 06:30 PM
k0reanrenegade
Jan 25, 2004 04:37 PM
DA-MAX
Sep 4, 2003 05:00 AM
