Main Relay Keeps Clicking Constantly
Old Apr 19, 2014 | 04:05 PM
tech410's Avatar
Default Main Relay Keeps Clicking Constantly
First off, I just got home and had my car sit for about an hour. I went to my car and turned the ignition on, all of a sudden my main relay starts clicking constantly. I unplugged it and then plugged it back in, turned the ignition on and same issue, the main relay just continues to keep clicking and at the same time I can hear the fuel pump turn on. So, I disconnected the battery for about a minute, and tried it again, same issue. I even tried to 2 other main relays and still same issue. I also noticed that the fuel injector plugs are making a clicking noise at the same beat of the main relay. Could this be a bad fuel pump? I am lost on this and not sure what it could be. Has anyone had this problem?
Old Apr 19, 2014 | 04:33 PM
PinkBatman's Avatar
Default Re: Main Relay Keeps Clicking Constantly
I had a similar problem once, ended up being one of the under-hood fuses, don't remember which.
Old Apr 20, 2014 | 07:27 AM
ProjetEF's Avatar
It sound like unsufficient voltage, are you sure your battery is okay ?
Old Apr 24, 2014 | 05:05 AM
tech410's Avatar
Thanks guys. I charged my battery and re-wired all my main grounds in the engine bay and that seemed to have fixed the issue.
ckirso
Mar 18, 2013 08:08 AM
Naiyasin
Dec 12, 2010 07:21 PM
DnB TeK
Jun 22, 2005 02:46 PM
camo_crx
Apr 6, 2005 01:33 PM
triple_s1x
Feb 27, 2005 11:10 AM
