ZC vs B16a
Old Oct 29, 2002 | 10:57 PM
Rydaddy's Avatar
Default ZC vs B16a
Okay, my original plan for a swap into my 91 Civic Si was a B16a. After doing some research (and shelling out more money than expected for a paint job and other misc stuff) the ZC motor is starting to look pretty good. I am told that I can use my Si tranny with the ZC, and the ZC just bolts right up in the factory location, saving about $1000 on tranny and mounts. My question is this: How good is an all-motor ZC vs all-motor b16? I REALLY want vtec under the hood, but I wouldnt be able to build the inside of the B right away like I would a ZC. I know that a lot of people force induct ZC's, but how about going all motor? Help...i cant decide!!
Old Oct 29, 2002 | 11:32 PM
kinesistech's Avatar
Default Re: ZC vs B16a (Rydaddy)
You need to get d16y7 head. It will raise comperssion higher than a zc and everything esle from your engine fits. Just get an FPR to raise the pressure a little.
Old Oct 29, 2002 | 11:56 PM
Jesse H's Avatar
if you're considering ZC, also consider the SOHC VTEC instead. Same power, better aftermarket.
Old Oct 30, 2002 | 12:07 AM
texan's Avatar
Default Re: ZC vs B16a (Jesse H)
An NA ZC won't even begin to compare to an NA B16, that's the B16's bread and butter. In a very light car especially, the B16 can really shine. But speed costs money, how fast do you want to go?
Ps- The B16 also takes extremely well to turbo setups, 10-12 psi on stock internals is reliable with proper tuning and proper driving technique.
Old Oct 30, 2002 | 12:53 PM
JaeOne3345's Avatar
Default Re: ZC vs B16a (texan)
zc built with dual weber or mikuni's would surprise a lot of b series motors.
honda_coupe
89
Jun 23, 2006 10:29 PM
LorenGeist
24
Aug 18, 2004 05:43 AM
90CRXracer
Nov 27, 2003 05:51 PM
HatchBox
Jun 26, 2002 06:28 PM
IAIA
Dec 31, 2001 07:19 PM
