strut bars
Old Oct 29, 2002 | 10:56 PM
deviant1's Avatar
Default strut bars
What performance difference is there between the strut bars that mount using the shock bolts and the ones that mount on the metal of the shock tower? like spoon vs mugen.....
Old Oct 29, 2002 | 11:00 PM
poison's Avatar
Default Re: strut bars (deviant1)
they are pretty much the same and do the exact same effect.
just different mounting positions.
Old Oct 29, 2002 | 11:41 PM
DevilSolSi's Avatar
Default Re: strut bars (poison)
from wat ive heard the ones that bolt to the chasis are better as they dont add extra stress to the shocks/struts....neuspeed strut bars bolt to the chasis...
deviant1's Avatar
most of the shock nut mounting ones have pivot points right? the mugen one doesnt have any pivot points right? no pivot points=less flex? how much the mugen ones go for?
Old Oct 29, 2002 | 11:42 PM
DevilSolSi's Avatar
yea the ones witout the pivot points are the ones to get....moogenver priced
Old Oct 29, 2002 | 11:44 PM
FifthGearOnline's Avatar
Default Re: strut bars (DevilSolSi)
just get a generic one off ebay for 20 bux, and see if that is enough strength for you.....if so cool you got one cheap as hell. But if not, turn around and sell it on ebay, and buy a stronger one
Old Oct 29, 2002 | 11:54 PM
Amuse9's Avatar
Default Re: strut bars (FifthGearOnline.com)
from solving my earlier problem by using this diagram, the best one would be a solid neuspeed bar with no pivot points that bolts to A/B for a 96-00 civic
Old Oct 30, 2002 | 03:54 AM
DevinW's Avatar
Default Re: strut bars (CivicSedan)
So the far best one IMO is the Carbing bar...it bolts to the shock towers and also to the firewall...It has a triangular shape
Old Oct 30, 2002 | 09:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: strut bars (DevinW)
That is probably true. However, in regards to non-triangulated bars, probably the best shock tower brace, at least in theory, are the Neuspeed ones for 92-95 Civics and 94-01 Integras that bolt to the upper control arm bolts. Think about when you go through a corner, and you get lateral (sideways) forces through the car as you round the corner. Those lateral forces transmit through the tires, wheels, hubs, and directly to the upper and lower control arms. The shocks don't do anything except control up and down motion. So a bar that braces the upper control arms should, in theory, be the most effective design.
Sliminem
Jun 29, 2003 02:25 PM
asmallsol
Apr 5, 2003 12:58 AM
speedevo
Feb 7, 2003 05:04 PM
B2FiNiTY
Oct 7, 2002 05:36 AM
dliao
21
May 16, 2002 01:14 PM
