Vss location b18?
Old Apr 18, 2014 | 05:33 PM
EgLuv94's Avatar
Default Vss location b18?
I have 94 eg with a b18b1 swap Ls tranny. My speedo works half the time, but its either at the correct speed or at zero. From what i think its the vss but i dont know where its located to replace it. Any help would be great.
Old Apr 19, 2014 | 06:25 AM
Black93Lude's Avatar
Default Re: Vss location b18?
It'll be in the transmission, near the output shaft.
An intermediate reading could be anything, Obviously, check the obviousness. Looseness, frayed harness, **** like that. If everything appears to be good at first glance you can either throw parts at it or have it tested.
Old Apr 19, 2014 | 01:58 PM
EgLuv94's Avatar
Would changing the cluster help? And so your saying the vss is inside the tranny? So i would have to pull the tranny to get to it right?
Old Apr 19, 2014 | 04:14 PM
mechanix619's Avatar
The VSS is technically inside the transmission but the transmission doesn't have to be removed in order the change it.
It's should be pretty easy to find. It's next to the output shaft and has a wire harness connected to it.
Old Apr 20, 2014 | 07:11 PM
EgLuv94's Avatar
When i looked the part up it had a gear on the end of it. Does this mean i will have to line up the gear slpines on the new part to the ones inside the tranny? I found where tge vss is i just dont know how hard it will be to replace.
Old Apr 20, 2014 | 08:07 PM
It's easy to replace. The gear will have to be aligned but it's not hard.
Rooftop voter
Transmission & Drivetrain
Apr 23, 2010 08:44 AM
spiderhatch
Dec 1, 2007 04:27 PM
kredican
Mar 28, 2007 09:02 AM
Boostage
Jul 2, 2006 08:08 AM
incredteg3
Nov 27, 2004 10:42 PM
