junkyard turbo questions
actualy i did a search..but the first question was more ritorical then factual..i was looking for backing ideas on it..as for what could i get it from i cant find a list of cars that uses them stock
but thanks for your time anyways
mike
mike
http://thenew.gamesbbs.com/~turbosi/
this is the only thing i found and i dont realy get it
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
what don't you get about it?
they do have a list of most OEM turbo cars and the turbo nomenclature to it.
the most common turbos used are t25 of the DSM cars later models, 14B DSM cars earlier models, T3 very common, domestic and imports. and KKK turbos of the euro cars.
stan
stan
wat should be done to a used turbo in order to make sure it is gonna wokr properly....liek when people say to have it rebuilt....wat exactly is done....wat should be looked for in a used turbo?
blah you could of did a search but imma help you out and not be a dick.
not saying that you guys who said search are, but hey help the kid out.
12:1 Vortech fmu
inline fuel pump
eclipse bov
thunderbird turbo-i have a freshly rebuilt one for sale i might add. $250+shipping!
starrion intercooler or izusu truck core intercooler
custom dp.
bigger exhaust.
um charge pipes.
oil line kit from ben drag one. its like 100 bucks.
um thats all i can think of newbie.
all fords and merkurs use a t3 manifold however since you have a sohc i recommend checking this site out mad info on how to rig your sohc with the stock manifold to use a flange and bolt a dsm turbo.,
http://www.homemadeturbo.com
there you go
later
12:1 Vortech fmu
inline fuel pump
eclipse bov
custom dp.
bigger exhaust.
um charge pipes.
there you go
later
Check these out, as far as where you can get them from (and search!)
http://www.geocities.com/ttskipp/turbochargers.htm
does anyone know what the numbers on that site (junkyard turbo list) mean?
i.e. GAR TB0344 would that be smaller than GAR TB0359 I would assume?
would it be a t3 /w 44 mm compressor?
Sonny
You really should consider looking into T3/T4's as well, as they have the same flange for the manifolds as the T3's (which makes sense, considering that the "T3" part of a "T3/T4" turbo is the turbine housing), and will generally make better high end power. Do a search, there's LOTS on this in past threads
i always thought it was the other way around....t4 was the houseing and the turbine was t3...havin a smaller turbine would make it spool quicker with the potential to flow more air with a bigger housing
Terrabomb
Jul 13, 2004 06:28 AM
