Can you point where this vacuum line should be?
Old Apr 17, 2014 | 08:16 PM
hero06's Avatar
Default Can you point where this vacuum line should be?
I found this hanging under my lude. Can anyone point out where should it be connected?
Old Apr 17, 2014 | 08:33 PM
gzes's Avatar
Default Re: Can you point where this vacuum line should be?
Well posting your year might be a little helpful....
Old Apr 17, 2014 | 08:42 PM
hero06's Avatar
My bad. It is a 2001 prelude SE.
Old Apr 17, 2014 | 10:57 PM
snobordboy's Avatar
Moderator
Looks like the one that would run over to the vacuum box for the intake, that is over by the battery. If you have an aftermarket intake on there, the box can be removed and the nipple that line comes from capped off.
Old Apr 19, 2014 | 06:19 AM
Black93Lude's Avatar
Yea, It looks to be the same as my '93. If so, it runs over to the intake and actuates a door that opens at a certain RPM to allow more air thru the intake system. Mine is deleted as it has an aftermarket intake. From the '93 VECI label, its not an emissions control device. Check the label under the hood on yours to see if Honda changed it for '01.
Bleakened
May 17, 2013 11:37 AM
MilanoLude
Sep 24, 2007 03:19 PM
Glow_Lude
Jul 26, 2007 04:22 PM
tacticalcustoms
Oct 6, 2006 01:17 PM
sony224422
Jul 21, 2006 02:43 PM
