93 eg/b series swap - EK ac install
Old Apr 17, 2014 | 07:26 PM
Lebronsito's Avatar
Default 93 eg/b series swap - EK ac install
Please some one help me i have a condenser, evaporater, and ac lines that came of an ek but i have an eg with a b series swap i want ac on it but have no idea what to do i also have the b series compressor but the ek lines dont fit. I was told that i have to get the original ac that came with my 93 eg which is a single cam compressor and i have a b series motor so im confused on how to put ac on a swapped eg please someone help i need ac asap i hate the heat!!
Thank you very much
Old Apr 18, 2014 | 02:58 AM
tony_2018's Avatar
Fish Twig
Default Re: 93 eg/b series swap - EK ac install
So who told you that you need the ej ac lines and a b-series ac compressor to make it work in an eg?
Old Apr 18, 2014 | 04:50 AM
egsleepercivic's Avatar
get the original AC meant for your car including compressor lines etc, then get the bracket for a del sol vtec (P54) or a 97 crv (P7J)
The only thing different than the stock AC that came with the car is the bracket when you swap a B series into a 92-95 civic
Old Apr 18, 2014 | 04:52 AM
kyden's Avatar
who told you 96-00 parts fit?
Old Apr 19, 2014 | 03:40 PM
Lebronsito's Avatar
Thanks the person that told me was the one that sold me the all the ac components so i figured since its a b series it will need a b series compressor not a single cam one
Old Apr 19, 2014 | 06:59 PM
tony_2018's Avatar
Fish Twig
gtfoh
Old Apr 19, 2014 | 07:14 PM
PrettyMuchBoned's Avatar
Why won't compressor brackets etc for the engine, work in his car?
Old Apr 20, 2014 | 05:16 PM
Lebronsito's Avatar
Yes i have an eg but i have a b series on it and i have a b series compressor but they told me it fits
Old Apr 20, 2014 | 08:38 PM
tony_2018's Avatar
Fish Twig
If your car didn't come with a/c, or it was removed, you basicly want to keep everything the same as the car itself. del sol vtec has the same design as an eg but there are still some differences. You'll need to locate a del sol vtec a/c bracket in order to use a eg a/c compressor. Also the usdm eg civics never came with a b-series so therefore the next best thing is the del sol vtec. The reason why you there are part differences is because the integra compressor is a different size than the eg d-series compressor. You might think you can get away with using a b-series ac compressor and twisting the a/c lines to match up to the compressor but your risking it. Up to you.
1sikhatch
15
Aug 12, 2010 01:51 PM
MeanusGeneus7
Jan 14, 2010 08:05 AM
fitbmx86
May 6, 2007 11:48 PM
Demon_Dub
Dec 11, 2003 06:53 AM
