b18c1 into 99 civic automatic
Old Apr 16, 2014 | 03:55 PM
silver99ex's Avatar
Default b18c1 into 99 civic automatic
Ok so first off I know this is an old swap and I have searched it but havnt found anything on changing from auto to 5 speed. I travel a lot for work and got a 99 civic ex automatic for it. But its got 219,000 on it and I want to change it. Never been a d series fan. So I plan on buying a whole integra and doing the swap. My questions are these:
1. Will I have everything I need for the swap or will I still need the 2 si mounts?
2. How do I go about putting the clutch pedal, clutch reservoir, and shift linkage in?
3. The civic has great AC and id like to keep that, how?
Im a decent mechanic and bot new to hondas. I've had an rsx, built ls teg, and got an accord sport now. Any help would be great, thanx
Old Apr 16, 2014 | 07:21 PM
aavtec's Avatar
Default Re: b18c1 into 99 civic automatic
You need manual trans mount, si rear mount, all clutch (pedals, lines ect..) parts, b series axles and shift linkage. Also you will have to modify your wiring harness. To keep your a/c use the Honda CRV a/c bracket it will bolt up to a b series motor and to your stock ac compressor
New tech
Jan 29, 2015 05:57 PM
Ekbuild402
Transmission & Drivetrain
Mar 29, 2013 01:48 PM
Xcisions
Feb 19, 2013 06:25 PM
specialized108
Jun 10, 2007 06:11 PM
89flaredhatch
Apr 12, 2007 10:45 AM
