Can't get lock nut to fully tighten.
Old Apr 14, 2014 | 06:29 PM
OmgDelSol's Avatar
Default Can't get lock nut to fully tighten.
Hey everyone! My CSII suspension came in today and i'm finishing it up. When putting on the front passenger side i ran into a problem. The lock nut on the upper control arm will not go past the first couple of threads. It seems as if it's cross-threaded but i've taken off and on multiple times and it still does it. The bolt doesn't have a head on it so i can't prevent it from turning with the nut. Any suggestions? I've tried spraying it with WD-40 and it didn't work =[
Old Apr 14, 2014 | 06:57 PM
NerfGunner420's Avatar
Default Re: Can't get lock nut to fully tighten.
that one that connects the ball joint?
Old Apr 14, 2014 | 08:24 PM
Recktek's Avatar
Every possibly its a diffrent thread pattern so it will thread in a little but then cross thread
Old Apr 15, 2014 | 03:04 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Lock nut? For the ball joint?
Remove the nut. Take the ball joint stud out of the cast iron knuckle. Grab the SMOOTH part of the stud with vice grips. Turn the nut on the threads (impact wrench helps) back and forth a few times till its smooth.
Old Apr 15, 2014 | 08:29 AM
OmgDelSol's Avatar
Thanks everyone for the advice. I finally got it past the little "kink" in the threads!
Juans_MX3
42
Jul 10, 2021 04:38 PM
dtran002
Jul 15, 2010 07:13 PM
menkio
10
Mar 25, 2005 09:36 AM
brx017
31
May 2, 2004 04:01 PM
nugget8000
Aug 27, 2001 09:37 PM
