my TPS is reading is 0.13 Volts closed throttle
Old Apr 14, 2014 | 07:59 AM
gabrielsousa's Avatar
Default my TPS is reading is 0.13 Volts closed throttle
So my TPS is reading is:
4.39 volts open throttle.
can i adjust ? or i need to replace my TPS ?
Old Apr 14, 2014 | 09:53 AM
Former User's Avatar
Default Re: my TPS is reading is 0.13 Volts closed throttle
Calibrate to 0.5V at closed throttle and then measure voltage at WOT.
Old Apr 14, 2014 | 10:28 AM
Can i calibrate to 0.5 ?
Old Apr 14, 2014 | 10:39 AM
Have you tried?
Old Apr 14, 2014 | 10:40 AM
No the difference is só huge
Old Apr 14, 2014 | 10:43 AM
Are you looking for advice? If so, then try to calibrate the TPS voltage as I suggested. Post the outcome.
Old Apr 14, 2014 | 11:18 AM
br8crumb's Avatar
its ashame how many ppl post about the throttle position sensor..... there are slits so u can move it side to side for a reason.. calibrate it closed at .5v closed with the motor off but in the start position.. and then when its at .5v closed bolt it down and recheck.. then measure at wide open throttle... theres a bump stop for the throttle which can be adjusted for WOT if it doesnt read correctly.. once u have the tps calibrated unplug the battery for a few mins so the ecu resets -.-
Old Apr 14, 2014 | 12:42 PM
manage to calibrate to: (the max i can do is)
0.32 Volts closed throttle
4.62 volts open throttle.
i need to replace it, right ?
Old Apr 14, 2014 | 01:48 PM
with the TPS from right(or up) (bigger hole) manage to put
0.50 Volts closed throttle
4.80 volts open throttle.
luckily i had other TPS
Old Apr 14, 2014 | 02:57 PM
i think i have the 2 TPS with problens,
the TPS with iron ring should do to 0.50 right ?
Old Apr 14, 2014 | 06:27 PM
br8crumb's Avatar
the rings should be there but i dont think it will really do much since the inside sits in a slit on the tb. however, if u think the tps is bad u can always buy a new 1 from advanced auto etc and see if it reads right. if not u can return, or u can always clean ur old 1 up and return that and keep the new 1. seen some crazy **** when i worked there and i dont blame them
Old Apr 15, 2014 | 11:53 AM
reading of my TPS with metal rings:
Pins 1 and 2 ---> 0.11 kohms
Pins 2 and 3 ---> 4.44 kohms
what are the readings of a good TPS ?
Old Apr 15, 2014 | 12:02 PM
4drEF's Avatar
Keyboard Humorist
What kind of meter are you using?
Did you buy something really cheap that might actually read incorrectly?
Old Apr 15, 2014 | 12:05 PM
i'm using a multimeter ? good make, good shape .... i use it for many things is accurate
Old Nov 22, 2015 | 11:26 AM
Nato18's Avatar
I have an 1995 accord and at CT it reads .70 volts and at WOT 4.5.. What could i do?
Old Nov 24, 2015 | 06:35 AM
slo88rex's Avatar
You should have .5v at closed throttle. . . If it is not reading that then loosen the bolts, twist the tps until you have .5v. Make sure your throttle cable isn't too tight. I have seen where the cable was adjusted poorly and it caused the throttle to slightly crack open when it was supposed to be in the closed position.
Old Nov 25, 2015 | 10:02 PM
Post in the Accord forum.
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
TwoKSiR
Mar 25, 2008 11:11 AM
TheSav
Apr 10, 2006 11:23 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
