What's the right distributor (dizzy)
Old Apr 13, 2014 | 05:17 PM
Jefferin000's Avatar
Default What's the right distributor (dizzy)
Help I recently bought a swapped crx and everything seems to be good except I'm sure I have the wrong dizzy as it doesn't fit right and leaks, however the car runs decent. I was wondering if someone can give me some guidance as to what I'm dealing with and how far off I am. As far as I know I'm running a b18b1 block with a pr4-4 stamped head and a td73u distributor and an ecu that is written on for a 94 integra. I believe the motor is from a 93 ls integra. The car seems to run a bit rich but otherwise ok. Any info or suggestions would be much appreciated.
Old Apr 14, 2014 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: What's the right distributor (dizzy)
What ECU (P74, PR4, P75?) Is your car converted to OBD1? If so you'll need either a TD46U or TD55U from a 92-95 LS integra. Post pics of your distributor plugs.
Old Apr 14, 2014 | 09:40 AM
Unfortunately I don't know how to post pics. The ecu is p75 and the dizzy clips are 2 white rounds into 2 white rounds. My thought is I need to get the obd0-obd1 conversion jumpers and get the td55u dizzy and bada boom. Will I just be able to plug in and go or will I have timing issues and what not. Thanks.
QUOTE=HondaPartsHero;49652961]What ECU (P74, PR4, P75?) Is your car converted to OBD1? If so you'll need either a TD46U or TD55U from a 92-95 LS integra. Post pics of your distributor plugs.[/QUOTE]
1987HondaCivic
Jul 10, 2015 07:41 AM
JuneBugDrfter
Aug 8, 2013 12:39 PM
kcvi3tstyl3
Apr 6, 2009 08:32 PM
thirteen20CRXSi
Nov 15, 2008 08:25 AM
greenDC2
Dec 22, 2005 10:17 AM
