auto tranny not shifting
Old Apr 13, 2014 | 02:15 PM
ek9monster's Avatar
Icon2 auto tranny not shifting
98 civic dx hatch d16y7 auto i have been through 3 trans missions and they are all doing the same thing they seem like they are stuck in low gear i bought a new ecu 3 new trans all the sensors and it is still not shifting. im running out of ideas plz help me
Old Apr 13, 2014 | 02:30 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: auto tranny not shifting
You change the solenoids in the tranny?you check your shifter? The plastic could be worn. What kind of fluid are you using?
Old Apr 13, 2014 | 03:32 PM
AutoWiz's Avatar
sounds like a harness, connector, power, or ground issue if all related components have been replaced. I have seen corroded connectors at transmission solenoids. also if the vehicle was ever in an accident, you can check damage area for pinched or broken harnesses. and does the vehicle speed sensor work? does the speedometer show a steady and accurate reading as the car moves?
Old Apr 14, 2014 | 06:31 AM
ek9monster's Avatar
No car was never in a wreck I went through 3 trannys and the speedo stoped working when I chNged the tranny. And honda ATF
ek9monster
Transmission & Drivetrain
Apr 13, 2014 09:08 PM
zenon8890
Feb 28, 2008 12:22 AM
UltRaH22
Feb 2, 2004 04:24 PM
EL-Driver
Nov 12, 2003 12:20 AM
ctreber
Nov 9, 2002 05:57 AM
