J12 Question (back to stock)
hi guys, Working on my cousin car, and had little problems with the turbo, so he order a new one.
Now, I put stock injectors, map, header and put the j1 switch to off. So back to stock p30.
Question is: Do I have to resold the J12 or she works like this?
You don't have to touch j12
mtber, having a issue, when disconnect the MAP sensor, the CEL not pop ON and not want to rev., connect it and no rev it chokes.
Can you give me a hint?
Make sure you don't have the TPS and Map sensor plugs mixed up.
The tps plug will have a red middle signal wire on it.
codes don't always pop up right away, sometimes you have to drive it a little for the ECU to process an error. Also make sure the engine light isn't burned out or been removed, I've been seeing that far too often lately.
