when you cant do a compression test, do this
Old Apr 11, 2014 | 06:03 PM
uberEFtuner's Avatar
Default when you cant do a compression test, do this
I did a leakdown test and one cylinder was leaking about 25% more than the others. So once the head was off, I was wondering If it was true that the rings could be tested with the head off.
Test 1: CONFIRMED
I put all the pistons to the same height and filled them up with oil. After 2 weeks the suspect cylinder had almost no oil in it.
Test 2: CONFIRMED
I plugged up all the holes in the block with rags and refilled the cylinders with oil. Then I applied compressed air to the dipstick tube. Small bubbles leaked from ALL of the cylinders, but the suspect cylinder was bubbling like crazy.
Old Apr 11, 2014 | 06:11 PM
95accordCE6's Avatar
Default Re: when you cant do a compression test, do this
Good info, I never would have thought of that...but I also have never been in that situation, probably wouldn't be patient enough to wait 2 weeks lol
02BladeRider
Jul 7, 2017 05:49 AM
blue_dlb
Jun 9, 2013 08:40 AM
model x
Oct 26, 2005 02:01 AM
aracer69
Nov 16, 2003 06:14 PM
mick
Jun 7, 2002 07:43 AM
